Thread: IC pump
Old Oct 3, 2007 | 04:35 PM
ShawnQ's Avatar
ShawnQ
Default Re: IC pump
Originally Posted by MMZ_TimeLord
ShawnQ,
Not without a coolant reservoir, it won't. The only thing it will do is last longer than the stock pump (based on what I've read about the Bosch pump failure rate.)
I will probably install a reservoir by the end of the year. But for now, I'm just happy that the pump won't fail (again based on the numbers and feedback from various users.
Cheer!
I kind of caught this thread on the tail end...but I assume you all are upgrading to a more durable pump that is renowned by the AMG/MB guys?
Someone needs to make it 'plug -n- play'...
Is there a usual time when these stock bosch pumps fail? What causes the failure, the excessive heat?
SQ
