Re: Retaining keep alive memory in ecm & radio
Easy way to do this is to hook up a lower amperage battery charger to the system (2 amp is plenty) in place of the battery, without disconnecting the system from power. i.e. - hook up the charger to the battery cables and THEN disconnect the ground from the battery.
Hope that helps.
