Thread: 295 30 19
Old Oct 4, 2007 | 05:57 PM
BLACKSRT-6's Avatar
BLACKSRT-6
Default Re: 295 30 19
Originally Posted by MMZ_TimeLord
Just changed my tires last week. (need to post pictures).
I have 295/30R19s (Yokohama Advans). I need a 5 or 10mm spacer to keep it from rubbing the upper-inner-forward area of the wheel well at full suspension travel. Otherwise it's fine.
I was also able to put 245/35R18s (same brand and make) on the fronts and could probably go to 255s, but it would rub for sure. Takes full suspension travel now to get small rubbing.
Hope that helps... Cheers!
Thanks, that helps a lot.
I run 245/30/18 Kuhmos on the front with no problem. I think that I would have to trim the upper suspension bolt to fit 255s.
What offset and width rear rims do you run, I have 35 offset rears with 10mm spacers.
Thanks again for the help.
