Originally Posted by MMZ_TimeLord
Keep in mind if you don't upgrade your intercooler system (Air Charge Cooler) you will still heat up the cold air you are bringing in.
I would make sure to put some effort into adding a reservoir and larger intercooler in addition to the large CAI.
I do like the quality displayed here and the thought and engineering was very well executed.
I'll stick with the stock air boxes for now. When I get the Intercooler system upgraded... then I'll think about a larger and colder charge of air.
Cheers!
The point of a Cold Air Intake is to get rid of the inefficient factory filter and its restrictive tubing. In return you get
more, less restricted air from a cooler source (key word there is more).
