Originally Posted by BLACKSRT-6
What advantage do you anticipate from 265s in place of the 295s? Thanks.
Same height with less rotating mass and unless you are planning on screwing with the fenders on the front of the car to fit bigger than a 245 you will be driving around understeer constantly. I have set my car up to work with the 295s and it is fast but I think it is faster on the smaller tires. I am not sure what you are looking for? If you are autocrossing in stock class than run 245/35/18s in the front and 265/35/19 in the rear or you could run the 235/35/19 which is ironically just as wide as the 265 but a bit shorter.
