Thread: New Nittos
Old Oct 6, 2007 | 07:50 AM
SRT SIX's Avatar
SRT SIX
Default Re: New Nittos
Originally Posted by BlackCrossFire6spd
I have these tires on my car. They are quiet, look good, and have a nice tread pattern, but the conti's held the road better. They have good wear, but I found you need to inflate the fronts to about 37-39 PSI for even tire wear. at 32, I was wearing the outer edge faster. They are great tires if you don't do a lot of "spirited" driving, otherwise, you may be disappointed in the downgrade in grip. Also, check pricing on: www.discounttiredirect.com. I think they have them for less.
BlackCrossFire6spd,
Unless the Limited and SRT6 have different pressures, the recommended pressure printed on the door jamb is 36. That might be some of the reason for the outer edge wear. I generally add 1-2 pounds anyway.
Thanks for pointing out Discount Tire Direct. Actually Americas Tire Co and Discount Tire are the same company. I did a quick online comparison and noticed how similar the web pages are. In fact on the Americas Tire page it also lists Discount Tire. Not so with the Discount Tire page.
Yes Discount came up cheaper (I was told it should not).
Fronts were $15 less
Rears were $21 less
Americas Tire has local stores and that is where I went. Wrong for me, but I did not check what was being charged. I have always used Americas Tire and have been very satisfied.
Further checking my invoice I found other errors. The repair facility is mounting and setting my TPS sensors and disposing of the old tires.
Americas Tire charged me $2 each to dispose of the tires they will not touch and they charged $12 each for installation, something else they will not be doing.
All told the difference was $126. I WILL be getting a refund for the difference. Thanks again...
