Old Oct 7, 2007 | 02:23 PM
msheredy's Avatar
msheredy
Default Re: Max N/A Horsepower...
Originally Posted by Maxwell
I don't see the head studs to be a weak link, since the SRT6 uses similar design head if not the same heads. the SRT6 puts out 410 hp modified, so the heads studs can easily handle the pressure.
That's provided that the limited/base models use the same hardware as the SRT. Based on experience I tend to believe the AMG built engine would use better grade hardware such as ARP for example.
The weak area might really be the crank NA, but who knows?
Since his question was max horsepower for a normally aspirated engine the crank should be fine. If you started spraying or boosting then the crank becomes a liability.
Big bore kit would be a safer upgrade, if only you can find a shop skilled enough to make a quality piston with plenty of valve relief, preferably forged alloy slug with new sleeves.
LA sleeve carries a full sleeve kit for LS1's for only $750, not bad price for speed parts, granted you do have to hone them to fit your piston.
That would be awesome if there was a reasonably priced stroker kit for us.
