Originally Posted by matadorCE
well if the s/c gets turned off then you won't boost which will show in the boost gauge. so i'd think having charge temp will be redundant.
You're right. I also want to see if there are signs, not just when the pump goes, of a failing pump. Gradual increases in air intake temp readings inform me of this.
