Originally Posted by BLACKSRT-6
I am autocrossing and SRT-6. I have Kuhmo 245/30/18 fronts and Pilot Cup Sport 265/35/19 rears. The car will turn in well but breaks the rear loose with even timid use of the throttle. Your using 295/19 Hoosiers, who makes 265 and 235/19 race rubber?
Thanks
All the tire sizes I mentioned are made by Hoosier. With the SRT-6 you might want to stick with the 295 as it does put more tire down to the ground. Just keep in mind that in the quest to get the power down better you will pick up understeer in any steady state corner unless you have Koni adjustable shocks like I do to help tune it out. Hope that helps.
