Thread: Question!!
Old Oct 9, 2007 | 08:05 PM
CrossfireLTD's Avatar
CrossfireLTD
Cool Re: Question!!
A significant drop in temp will set them off, since they are "trained" switching them might cause issues also. You can also have them filled with nitrogen which is less subjective to temp changes. I believe the tire pressure should be 32 psi front and 33 psi rear. The sensors go off when there is a 25% psi loss, could be set off by one tire or a combination of tires.
