Old Oct 10, 2007 | 04:16 AM
simon-srt6's Avatar
simon-srt6
Default Re: Disconnecting Battery
Cheers, how will the emissions be affected by disconnecting the battery ? I thought the Lambda sensors adjusted mixture from analyzing the exhaust to fit a "map" / "profile" ?
The reason I was asking as I was told to fit a sprint booster, I need to disconnect the battery or it won't work. I am fitting it tonight so am I a bit concerned now that the car won't work after unless I do this and if I do, the emissions could be out and if that is the case it could be causing engine damage (depending on how far out it is).
