Old Oct 12, 2007 | 06:02 AM
LantanaTX's Avatar
LantanaTX
Default Re: Pls Need Help From The Xfire Pro's
Originally Posted by Fenwick223
Ok, I couldn't stand it so I just went outside and tried to start my XF. As I suspected, STARTED RIGHT UP! This is why I really hesitate having it towed to a dealer the next time it doesn't start because, by the time I get it there, it will start and they won't be able to diagnose what's wrong. I may just have to take it in and let them try to start it for a week or two until it happens at their place. I believe it has to do with the security system (SKREEM?) but the manual said that codes are stored if there is any problems with this unit and no codes appear. Either this is a complicated issue that is hard to diagnose or it's something as simple as needing a new battery, which I hope the dealer would have checked first. Since mine's an '04 maybe I'll just replace the battery since I will have to do it one day anyway and see if it still has starting issues.
If your car cranks but won't start occasionally or dies as you come to a stop light, it is probably the crank position sensor. This is a very common problem with these engines as they get a little older. As these Crossfires are now getting a little older I'll bet we will see this problem all the time. If it won't do anything occasionally I would check the park/neutral safety switch.
