Old Oct 17, 2007 | 12:20 AM
jonnyangel04's Avatar
jonnyangel04
Default Diy Heat Exchanger
Came across this on mbworld I want to do this to my SRT6 but am wondering what if any effect it would have?
I'm having Ron Davis make me a secondary front mount heat exchanger which I'll get in a few weeks. Meanwhile I decided to split the intercooler coolant circuit, add a reservoir, and wire the pump to turn on when in accessory mode. I kept my stock pump for now until the heat exchanger arrives, but will swap in a CM30 during that install.
No IAT logging done before and after splitting the circuit since I was going to do it anyway for the new HE. I plan to log temps with this setup and then after I install the HE.
Pics of course...
Here are the components for splitting the circuit. Reservoir, mounting bracket, hose clamps, 3/4" hose splice, and 3/4"-5/8" hose splice. I made the extension bracket and tapped it for mounting.
Cut the Oetiker ring style clamps off existing line and remove stock tee. Reconnect hose using 3/4" splice and install new clamps. Install the reducing splice into the intercooler circuit.
Run a 5/8" inch heater hose to the reservoir.
Here's the wire I grabbed for switched power to act as the trigger on the relay I installed for always on pump operations. It was a pain in the butt to find but that wire goes to a relay stuffed in the corner of the fuse box. There might be other options but this worked well for me.
