Old Oct 17, 2007 | 03:55 PM
patpur's Avatar
patpur
Senior Member/Moderator
Default Re: New Owner with Question!
After I did the reset it took overnight before the problem cleared up?
try the battery fix if that doesn't do it your options that I know of are stop light switch (works off the brake peddle), steering angle sensor or the ABS sensors. You have to get someone to pull the codes for you if our fixes don't work. Good luck and let us know how you make out.
Pat
