Originally Posted by NeverEnough
I posted how to spot a Track ***** a while back... If the car has less than 4,000 miles, carefully inspect the following items...
- Driver's seat wear. With that few miles the seats should still look "almost" new. If there are any pronounced wear and rub patterns on the outside bolster then it is suspect.
- Floor mat and carpet wear. Specifically in the heel pad and foot rest areas. If there is already a noticeable wear pattern, then it is suspect.
- Noticeable wear on the brake pedal. Look for shiny worn spots on the edges of the metal. Are all the rubber nubs even and not worn down or rounded off?
- Scratches and uneven finish on the shift ****. If the shift **** is worn shiny smooth on either side or on top, then it is suspect.
- Inspect the brake pads. With that few miles they should have about 90% left. If they are noticeably worn, it is suspect.
- At 3-4K miles, the tires will show some wear and probably won't have many rubber "hairs" left. If the tires look NEW NEW and have 100% full tread depth then they may have been replaced already, that makes it suspect.
- If the tires have major wear on the outside edges and have notable tread gone, then suspect it.
- Last, but not least, the "Window Cleaner Test" FTW! Take a can of aerosol window cleaner like Stoner Invisible Glass or similar brand(must be aerosol. Normal spray bottles like Windex don't work as well. Spray the top 8 inches of the windshield with the cleaner and wipe off the foam. quickly look and watch as the residue evaporates. If there was a Track Experience Sticker(they are LARGE) on the window at some time, there will be a "ghost" image of it that evaporates at a slower rate than the rest of the glass. It sound funny, but it sticks out like a sore thumb. It's hard to miss.
Hope this helps.
Very good points and this is helpful. I have gone over most of what Shawn and you both have mentioned. No extra wear inside but I don't know what the deal was with the wheels being removed many times. I was thinking that other rims and tires were on and off frequently. You know how your imagination can run away at times. I think it is great to offer the "Track Experience" but I feel strongly that it should need to be disclosed. Maybe giving a free bumper to bumper 7/100,000 would give a good piece of mind. On the other hand, wouldn't you think that the people running these promotions would want to impress everyone to the max and mechanically maintain these cars so no breakdowns occur?
Steve
