Re: Replacement wheel advise
I went with a staggered set (18x8 and 18x9) Mercedes wheels. They have an offset of 32 which is close to stock for the front but not the rear (22mm ET). To get things right I had to run a 10mm hub centric spacer in the rear. The car rides much better by getting rid of the heavy *** 19's and seems quicker and more responsive from a dead start. The tires I used are 225 40 18 in the front which are stock and 265 40 18 in the rear which is about the same in diameter to stock but 10mm wider than stock. the other real benefit is I now no longer have to think about $1,000 set of tires. The price range for 18's is much much better. I still have the raked look because of the larger tire I am running in the rear.
