Originally Posted by ShawnQ
Great pics neverenough!
Now who is going to be the first one to take a stock airbox and 'modify' it to fit over top of the needswings intake, so that the engine cover doesn't look like half of it is missing?
How 'solid' is the mounting? It looks like a few bumps may cause it to slip out of the flexible areas unless the ends are flared to rolled.
SQ
If it's installed correctly, I can't see how it could slip apart. The main aluminum Pipe slides into each coupler about 1-1.5 inches and there is no room for it to move around at all. I would be SHOCKED if it didn't stay together. All the fittings are tight to the point of needing a lubricant to get them to go together( I almost thought the couplers were too small at first). She ain't going anywhere, I can promise you that.
