Re: Byron Dragway Results (hold you breath)
An A/F ratio check is extremely critical at this point. Anyone know what fuel injectors we're running in these cars. With my '04 cobra, there came a point where the computer can tell the fuel system to deliver more fuel, but the injectors were maxed out. If you're running dangerously lean, you may just have to upgrade to a higher lb/hr injector to make up for the discrepancy, assuming the ECU doesn't have a max cap on the amount of fuel it will allow to the engine...but if that were the case, I'd expect a CEL or code of some sort to be thrown.
Congrats on those times...sounds like your car is a real scalded ape now! I've got my fingers crossed on your A/F ratio.
