Old Nov 1, 2007 | 07:26 AM
Haywood's Avatar
Haywood
Default Re: HELP! - No Remote Turn on from Scosche Harness
Originally Posted by JonZoidberg
I had the same problem. If you bought it from Crutchfield like me, then you probably got their crappy instructions. It says the pink wire is only used if you have some old Audi or something. It's the remote wire. I just did my install a couple weeks ago and I had to go back and wire it in.
Hope that helps. There was a red/white wire that I didn't use at all.
Ahhh, thank you. I did find the remote turn on wire on the factory harness before I read your post. FYI, it's the BL/DG wire that I tapped into.
