Old Nov 1, 2007 | 06:00 PM
Maxwell's Avatar
Maxwell
Default Re: SRT6 Brake Upgrade (FINALLY)
Originally Posted by -32-
Back to the subject, those PN's are incorrect. A big giveaway is there is a left and right side PN.
http://www.mbwholesaleparts.com/fmpc...assisShort=170
Choose a category then change Select Baumuster to one of the following:
170.447 for 1996 SLK 230K
170.449 for 2000 SLK 230K
170.465 for 2000 SLK 320
170.466 for 2001 SLK 32K
For base or limited, I'd select 170.465
For the SRT-6 I'd select 170.466
By the way, The rotors and calipers are the same on my SLK32/(C32) and SRT-6.
Hey thanks for that link, maybe you can clear up some mis-information. I understand that the SRT6 and SLK32 both have the same rotors and calipers, but Brembo's technical dimentions says the C32 is a larger rotor and it caliper is visually different than the srt6/slk32.
the slk32/srt6 are both; 330x46.4mm
the C32 AMG; 345x47.5mm
the C55 AMG; 345x47.5mm
so either your incorrect or the Brembo site is whacked. Also the C32 has a different rear differential which is another give away that the C32 is a beefier car.
