Originally Posted by ShawnQ
I know some others who have the N/A Car and not the SRT are having trouble with check engine lights and rich running engines when they add cold air kits. I'm not sure how the N/A car is setup, but I believe there may be a MAF sensor or something mounted before the throttle body which is throwing the code.
An ECU tune may be able increase the allowable parameters of the meter and prevent the codes.
SQ
If anything it will run lean with too much air... but it won't... MAF MAP IAT TPS 02's are all interconnected to adjust the timing and fuel flow... Sad but true... The car will maintain 14.7:1 no matter what you do to it !!!
