Old Nov 4, 2007 | 09:31 AM
tjames.bell@gmail.com's Avatar
Default Re: Will a Zex kit work??
Originally Posted by HDDP
Not sure what a shreader valve is... But, the TPS is a bit tricky on this car because it receives voltage feedback from the TB MAF MAP etc... As you know, this is a drive-by-wire system.
Quite painful to be sure...
Well the Zex kit does not have a actuall switch that activates the system like a NOS system, It has a wire that taps into a TPS line and to set it you hold the throttle down all the way and have a friend press a button on the solenoid box. When the signal that it recived when the button was pressed is met then it starts to spray. I just wanted to know if the TPS is somewhat like other cars or if it is commpleatly different?
