Thread: Byron Results
Old Nov 4, 2007 | 09:17 PM
ShawnQ's Avatar
ShawnQ
Default Re: Byron Results
Originally Posted by NeverEnough
As far as drag radials, I have seen several online shops that sell reman or knock off OEM wheels pretty darn cheap. I'm thinking that I will get a set of Mercedes 17" x 8.5" wheels and put some BFG or Nitto DRs on those. Should be able to do it for less than $900 easily. Maybe $800 if you find a deal.
Not sure if it is possible or not...but I DID see a mustang with Crossfire wheels on it. How? Not sure...but it had them.
I was thinking about mounting my 17" DR's off of my Mustang and seeing if they'll fit. EVERYTHING is cheaper for mustangs, even wheels. You could easily find a set of used ones if they'll fit. I know the rear XF wheels on the mustangs looked WAY too tucked, which would mean the mustang wheel will probably have more offset and stick out too far on the XF.
SQ
