I have noticed another problem that may be causing the wind noise. They did the TSB on mine and I still have it. Seems like the top front portion of the window, say 5-6 inches is not seated correctly and is out of adjustment. I can "gently" poke my key from the front corner of the window and back towards the rear. About 5-6 inches back the window makes a tighter seal and I can no longer do it. The passenger side is properly adjusted. I checked the cars on my dealers lot, over half of which I could do the same... the rest of the cars the windows fit perfectly.
Just something to check if your dealer is having some trouble getting your car fixed.
PS: To fix this problem as I described, they will have to tear apart the door to adjust the window track... ouch.
