Originally Posted by TVT_DESIGN
The two new products that are in development are a pulley set and manifold porting. The pulley set will be more then just the crank and priced significantly more affordable then EVO Sport.
The Manifold porting will be on an exchange basis and will offer different level of porting depending on application. Throttle body porting will be added at a later time.
Anthony DiMura
TVT Design
As mentioned in the previous post, thanks for taking an interest in mods for the owners of this car...
I do have a few questions which makes me think you don't have all you ducks-in-a-row when it comes to the engineering of this power plant... First, which manifolds are you talking about porting ? And which pulleys are you planning on altering and what would be the diameter ? Most importantly, how are you going to port the throttle body ?
Also, why would you develop a 2.5" exhaust system when the exhaust manifold outlet and exhaust headers are only 1.5" diameter... Don't you think you should address that issue first ?
