Old Nov 8, 2007 | 03:05 PM
Maxwell's Avatar
Maxwell
Default Re: TVT Design, an introduction
I was looking over the Startech 3.8L stroker kit and and it's really nothing special, what they are doing is installing the 3.7L ML320 sleeves and pistons in your block and then somehow are increasing the stroke by barely a smiggin' probably doing some mild machining trick to increase the eccentric. so your only gaining 0.1L with thier so called "Stroker Kit" plus they are installing the Schricks sports cams and doing the ECU reflash to bring the performance up to 300 hp, 291 lb-ft
I also think thier big brake kit is the C55 front rotors and AMG 6 piston calipers.
STARTECH uses the sports camshafts and a high flow catalyst in the exhaust to bring stock power up to 243 hp.
Originally Posted by Sidez
I am located in new jersey as well if you need any test fitments at a discount price you can rely on me... and yes about the stroker it is something we REALLY could use... as we to some point already have access to parts like pullies and an intake system.. well competition is good, but anyways..
for the stroker there is no competition... AT ALL...
