Old Nov 9, 2007 | 09:21 AM
NeverEnough's Avatar
NeverEnough
Default Re: NeedsWings Intake Review Part 3...
Originally Posted by Steve Hellums
I have a question about NEEDSWINGS intake pipe for you guy's that have done the install. Where the pipe goes through the radiator support, does it reduce down in size to go through it? I was looking at my car last night and could see no way a 3" pipe could go through there without a major modification.
If you look on either side of the radiator where the factory inlet hoes connect to the Radiator suppout, there is a large plastic Bracket/Air Valve/Inlet. This entire section is removed in order to run the 3" hose through. It's pretty easy and there is not restriction.
