Old Nov 9, 2007 | 11:54 AM
ShawnQ's Avatar
ShawnQ
Default Re: SL55 Y-Pipe Installed
Simon,
Go here:
http://www.americanvalve.com/flexcon...couplings.html
See if you can source something similar in the UK - any hardware/home store (if you all have those) should have it, or a plumbing supply.
If you look where the clamps seat, the coupling actually has a recessed area. I'm not sure if the recessed area is the right thickness, or the wider area outside the clamps. Either way, this piece cost $5u.s. or less
I used the 2"x2" coupler, and it stretches to fit VERY snug. Snug enough to where you use something to help it slide on, and possibly even heat it a bit to make it more flexible.
Hope this helps.
SQ
