Old Nov 9, 2007 | 03:11 PM
msheredy's Avatar
msheredy
Default Re: NeedsWings Intake Review Part 3...
Originally Posted by Steve Hellums
I have a question about NEEDSWINGS intake pipe for you guy's that have done the install. Where the pipe goes through the radiator support, does it reduce down in size to go through it? I was looking at my car last night and could see no way a 3" pipe could go through there without a major modification.
Steve, you should really get this! Once that bracket is removed the rubber hose finds its way through. The fact that you are cramming even more air into the engine because of your pulley set makes the OEM system even more of a restriction. You really need to let that huffer breath.
