Old Nov 10, 2007 | 05:04 PM
msheredy's Avatar
msheredy
Default Re: TVT Design, an introduction
Originally Posted by Maxwell
The proof that K&N is hard on engine life has been prooven. There are many oil analysis companies out there that have documented this. If you don't believe me do an oil analysis on two different cars, one with OEM paper filters and one with high flow K&N. looking at those reusable filters you can see way more porus opening for dirt to pass through. There is a reason why we use papre filters for cabin air filtration...
http://www.bobistheoilguy.com/airfilter/airtest3.htm
This guy doesn't even know his right from left (read the first sentence). He appears to be a self proclaimed oil guy, what ever that is, why is he talking about air filters? He isn't claiming to be the air filter guy. Also I browsed through the article and didn't read anywhere where he referenced oil contamination.
That note about getting oil on the MAF sensor and causing it to fail is B.S. too. K&N submerged a MAF sensor in their oil to prove that it [the oil] will not cause the sensor to fail. The result? Read here for the answer.
http://knfilters.com/MAF/massairfindings.htm
http://knfilters.com/MAF/massairpledge.htm
