Old Nov 13, 2007 | 07:07 AM
cgocifer's Avatar
cgocifer
Default Re: High pitched squeek between 1-2nd shift when cold
Originally Posted by moparman82
My srt has a high pitched squeek/chirp coming from somewhere (engine or trans) between first and second gear. It seems to be more frequent when cold but on occasion does it just for the heck of it. Sometimes it sounds like the trans since it does it at shift points. On the other hand it almost sounds like the engine belt slipping only for a moment (lasting 1/2 to 1 second) like when the supercharger has a load on it at the top of the gear. If any one has any ideas as to what it might be or maybe the same problem- -all help would be appreciated.
This has been discussed extensively on here. Just search for Chirp or Super Charger Chirp. It usually happens at around 2500 rpm, when the SC engages.
It is most likely the supercharger electromagnetic clutch engaging. This happens to my car as well, but has become very infrequent and almost non existant. The Mercedes AMG guys (AMG 32, AMG 55, most of the other SCharged versions) have this happen too. They have tons of self remedies for this including graphite compounds and etc. being applid to the spindle. Many people say this occurs just before the SC clutch goes out. I wouldn't worry about it yet. If you take it to the dealer, they will either do more work than is necessary, keeping your car for weeks, or they will say it's nothing and leave you with headaches. I say, just drive it until it stops with usage (especially if the car was sitting for long periods) or the SC clutch goes out completely (trust me, you'll notice).
Hope that helps!
