Old Nov 16, 2007 | 08:08 PM
DrMike's Avatar
DrMike
Default Re: Popping noise in rear end
Originally Posted by LouieLouie2000
My Crossfire started making a popping noise in the rear end late last week. It first happened when I was shifting the car in manual mode under moderate acceleration, I would give it gas and it would pop, I would let off the gas and it would pop again. It has gotten progressively worse... it happens when I go around corners or over bumps, or am just slowly idling through a parking lot. My mind instantly goes to a popping u-joint. But at only 47k miles, I find that hard to believe. Anyone else have a similar problem, or ideas of what it could be? Since my car is way out of warranty, where should I take it to get looked at, and not get completely shafted?
Open Rear Liftgate you will see area on both sides where paint seems to be chewed up from liftgate stoppers. Install a piece of dense foam available at aftermarket auto stores for installing pick up truck box. My noise gone now.
