Old Nov 16, 2007 | 08:25 PM
HDDP's Avatar
HDDP
Default Re: Le Big News...texas Srt6
Originally Posted by ShawnQ
Couldn't figure out the outside air temp, or didn't want to hassle with it?
Where do you plan to install the IAT? Is there something you can plumb into already, or will you be making your own port?
SQ
There is already a Bosch IAT sensor installed, this is one on the many data streams that the ECU / PCM uses to manipulate engine operation... Just access the data through the OBD port...
