Old Nov 17, 2007 | 02:58 AM
ctsemicon's Avatar
ctsemicon
Default Re: climate control wheels
What is inside the climate control is only two small 194-type bulbs....They use a big clear plastic "light-pipe" assembly that is supposed to transmit light from two bulbs all the way across face of both dials and into the wheel. Short of replacing the existing bulb with an arc lamp, this ain't gonna' cut it, and they always look dim. This is because original SLK design used yellow lamps on cream-colored fascia, andcontrast was much higher (same as speedo instrument binnacle).
One quick fix - replace existing existing t1.5 incandesent with LED Lamp. Or Eat More Carrots!
