Wider rim? what for? I ready have 8 inch in the front.
I was thinking maybe SRT front springs since they are stiffer that the limited's springs. Probably someone here has lowered their SRT and don't need the stock springs anymore.
I'd be willing to bet that the stock springs will work, it just may be a little more 'mushy'. Worry about getting the engine fitted and running, then you can worry about the springs. The minor weight difference shouldn't hurt you much. Put a wider/taller spring pad on it if needed for height, but I doubt you'll even need that. Well..maybe, I forgot you cut your springs...but, still, get it running first.
Keep it up man! I'm anxious to see 8cyls sitting in that engine bay for 1/8th the cost of Startech's upgrade...
BTW, I'm still digging those MB wheels.
Any idea which model MB wheels will fit our cars? I need a pair of 17's for the rear to run a drag radial.
SQ
