Old Nov 19, 2007 | 12:05 PM
jonnyangel04's Avatar
jonnyangel04
Default Re: SL55 "Y" & hose install w/pic's & results
If you take those tubes off you will loose 21 hp there is a dyno on MB world as for going larger even though more air is coming it is still going to be ristricted as soon as it hits the air filters. IF your looking to keep everything looking stock you should run the VRP air box AND sl set up thats the only way to see the gain your looking for unless of coarse you go the needswings route.
