Originally Posted by jonnyangel04
If you take those tubes off you will loose 21 hp there is a dyno on MB world as for going larger even though more air is coming it is still going to be ristricted as soon as it hits the air filters. IF your looking to keep everything looking stock you should run the VRP air box AND sl set up thats the only way to see the gain your looking for unless of coarse you go the needswings route.
I'm not going to take the tube's off, I'm going to go back toward the motor from the radiator support to where they start to narrow. cut them off there and add a bigger tube of some type to go through the radiator support, even if I have to do some mod's to get it through. It's just my opinion, but I think I can deliever more air with 2 - 2.25" to 2.5" pipes than 1 - 3 inch pipe.
