These cars could benefit from a stiffer rear sway bar.
that's on my list but I was thinking of machining a clamp that can slide back and forth along the torque arm of the sway bar, should help keep the exssesive weigh off the rear of the car when you upgrade to a larger bar. much cheaper than buying heavier bars, and the laybor of the install is much easier on the knuckles.
