Re: Mercedes SLK350 Transmission Question
I believe it will bolt up to the block, as it should be the same bolt pattern. I looked into this for our project car, but the ratios are rather similar, and the swap could get costly. You would have a much better shifting trans, that may hold up to more power though.
What are your thoughts? I may be able to answer some of your questions.
