Originally Posted by BDJ's Racing
This is what i worked on yesterday at my shop. The noise is not bad from under 2,800 rpm. WOT sounds just like a 350z with exhuast!! IMO. There are a few rpms from idlel to 300rpm that have a drone to them. All in all, not bad. I do like the tough sound i have.
I cut out the rear cats, and resonator. All aluminized Steel and mandrel bends, fully TIG Welded.
Performance, was a bit weird, i think it had some more throttle response and a hair more on the big end. mid range is about the same. IMO. I believe with the pulley and ecu, i will see all the exhaust gains.
I have modified my airintakes, K&N's, ported and polished my Throttle body and upper intercooler plenums, and added bigger tires in the rear. I have more pics of the calipers i coated and tires if peeps want to see.
Great work. It's good to see someone taking the hands on approach.
Where can I find the pictures of calipers and larger tires? (I'm thinking about doing 285/30 in the rear, but don't know about the look or rubbing issues.)
Thanks!
