Re: I need change the air filter.
remove the 2 intake ducts from the engine cover by slipping them forward toward the grille,grab the engine cover right below the chrysler symbol and pull up. where the 2 intake ducts conected there are 2 boxes 4 screws each all torx head t15 or t20 cant remember remove thoose screws and youll have the airfilters right there replace them reinstall screws blah blah just make sure you get the round seal around the mass airflow sensor (youll see it when you have it upside down) press down on all attachment points making sure its good and snug reattache intake tubes... your done usally takes 20 mins or so and yes the k&n's are good hope that helped!
