Old Nov 25, 2007 | 01:12 PM
LantanaTX's Avatar
LantanaTX
Default Re: Koni Is The Answer
When I first trimmed the stock SRT springs it would ride like that in the rear. Then Dan told me about the bumpers in the rear shocks (I did not remove the shocks when doing the trim, just removed the bottom bolt).
I went back and swapped them both out with a set small black bumpers I had. This made ride way too soft with too much body roll when driving aggressive.
I then trimmed about a 1/3 off of the stock bumpers and re-installed. The ride now is perfect, not jarring, but not to soft. Plenty of give on RR tracks, dips and those California cement freeways.
I think it rides better now then when it was new.
It's a cheap alternative ($0.00) you can try before spending any money. Not sure if the limited has this bumper in the shock.
Stop by Dan and I'll take you for a spin.
Here is a pic - it's hard to see the black bumper on the rod but it's there.
I trimmed my bump stops today. The car rides very smooth and could almost use a firmer shock. I could tell that since I lowered my my car, I was hitting the bumps stops on bigger bumps. I am concerned when you said with the small bump stops the car was too soft. I wouldn't want the bump stops doing the job of the springs and shocks. My bump stops were exactly the same as the one in your picture. I cut mine just about in half and used the half that has the groove in it. I put the flat side against the body of the shock and tappered end pointing up. I think I will go with Bilstein's aftermarket HD shock in the future. Another thing that helps my ride is the lighter 18 inch wheels in the rear.
