Some Problems with Mounting Hardware
My fabricator was supposed to provide both the springs for mounting of the upper grill and the screws for the lower grills. Unfortunately, unknown to me until recently, the screws he has sometimes provided have been a little too large to fit through the slats in the lower grills. What has happened is that there are not #8 screws available with a head the right size and he was going to turn the screws on a grinder to slightly reduce the head size so they would fit. Apparently sometimes he has done this and other times he has not. Please let me know if you need either screws or springs. (I think the springs that have gone out are OK) and I will send them by Priority Mail. If you want, you can reduce the screws you have by simply turning the heads slightly on the outer edge to reduce the size so they will fit through the slats. I apologize for this problem and oversight. Please contact me directly by e-mail regarding this at don@crossfiregrills.
