Thread: ESP Issues
Old Nov 28, 2007 | 10:38 AM
Display_Name's Avatar
Display_Name
Default Re: ESP Issues
Did you get stock size tires?
How's the inflation of the the tires? Did you check it with a known good gauge?
If directional, are all four tires mounted with the rotation orientation set up for going forward?
If the tires are still super-new (less than a few hundred miles) then then can still be a bit hard/slick.
Also, the PS2's really are pretty amazing in their ability to grip. Perhaps the difference in grip between your PS2's and goodyears (and your now mis-matched fronts ard rears) is enough that you are now discovering the reduced fun that comes with less capable tires.
(That pretty much exhausts my tire-related cause possibilities.)
