I've been trying to get the parts together to build this little circuit that basically will do the same thing as pulling fuse's 17 & 18, but doing it with a remote control. It has been a little time consuming trying to find all the components I was wanting, for instance the Cole Hersee RC-700112-NN (SPDT High power relays), two place's I had tried to get them from called me a couple day's after ordering them and said their supplier was out of stock and didn't know when they would be available. I finally got them ordered from NAPA on the 23rd and should be receiving them by the 30th of Nov. Both 17 & 18 fuse's are 40 amp, I doubt they pull that much, but you have to build the circuit to hold up to what it is fused at, the normally closed contacts on the 70 amp High power relays are rated at 60 amps. I had to go with this 70 amp relay because the heavy duty 40 amp relay's normally closed contacts are only rated for 30 amps. I got the # 8 gauge wire in line fuse holders through [/SIZE]
WWW.Radioshack[/SIZE], the brand name was monster car power. The remote control unit I got from [/SIZE]
allcorp@allcorp.com and is good for 6 amps( probably used for car alarms), the relay coils that the remote will turn on probably won’t pull 1 amp for both. The one thing I could not get after searching for a couple weeks off & on was male 90 degree flange electrical terminals to plug into where the 40 amp fuse's will be pulled out of, so I'll have to make the straight one's work. I've had the whole top of the fuse panel out and I believe all this little circuit can fit into the bottom of it. I wanted to get this all together and tested before I made this post, but I've had a couple people asking me about it after mentioning it on a thread. So here's the basic run down, you'll need a few feet of # 8 wire - mount the relay's on a small piece of metal that you can Velcro or bolt inside the bottom of the fuse box. Connect the # 8 wire of the inline fuse holders to # 30 on the relays, one for fuse # 17 & one for fuse # 18 and butt splice about 4 to 6 inches of # 8 red wire to the other end of the fuse holder wire so you'll have plenty of wire to feed up to connect to the hot side of where # 17 & # 18 fuse's were. Then I'm using # 8 gray wires to connect to # 87a terminals of the relays to run back up to plug into the load side of where the fuse's were. Now for the remote receiver it's pretty small, I'm planning on just tie-wrapping it to part of the wiring harness under the fuse panel. Run the hot output wire to # 86 of both relay's and the negative to # 85 of both relay's. To power the receiver you'll need another small in line fuse holder, you can tap off another fuse or in the rear of the fuse box where it mounts against the firewall there is a stud that only has power only when the car is on, then you'll need to find a place to get a ground for it and I don't know yet if there is anywhere inside the fuse panel to get a ground. This circuit will be de-energized all the time and the car should work just like normal till you turn it on to break the circuit. Here are a few pic's of the component's and where the wire's will be coming up from under the fuse panel, I just stuck a couple wire's through for an example, when finished, all you will see is 2 gray & 2 red # 8 wire's coming up from the underside of the fuse box connecting to where the fuse's use to be. The relay's & some # 8 wire = $21.00, # 8 gauge inline fuse holder's = $19, remote control device = $25, BEING ABLE TO DO DOUGHNUT'S with a click of a key fob, PRICELESS! For anybody doing this, for the first few day's of driving you should pop the top of the fuse panel & feel all connections for heat just for safety measure's, I don't think there will be any problem's. Sorry the pic's are split up, I'm having to go a different route loading pic's.
