Thread: ESP Issues
Old Nov 28, 2007 | 11:33 AM
msheredy's Avatar
msheredy
Default Re: ESP Issues
Originally Posted by Display_Name
Did you get stock size tires?
Yup.
How's the inflation of the the tires? Did you check it with a known good gauge?
They [PSIs] are to manufactures spec.
If directional, are all four tires mounted with the rotation orientation set up for going forward?
The rears are now directional and are mounted in the correct fashion.
If the tires are still super-new (less than a few hundred miles) then then can still be a bit hard/slick.
Yes they are still quite new. I can still smell the rubber when I walk up to them. I do know that they are gripping better than the worn out PS2s though. There is some run off water on my way to work and I would constantly spin the [old] tires when leaving from that spot. I don't do that anymore.
Also, the PS2's really are pretty amazing in their ability to grip. Perhaps the difference in grip between your PS2's and goodyears (and your now mis-matched fronts ard rears) is enough that you are now discovering the reduced fun that comes with less capable tires.
That is what I am beginning to wonder. Only I think that since my PS2s in front are almost at the replacement point that it is those that are limited in the traction department. I've read somewhere that these cars have a tendency to push. I might have made that issue worse now by having more grip in the rear than the front. Every other car I have owned has been somewhat numb to tire selection. This thing is really sensitive! As a matter of fact the minute I took it from Discount Tire I could tell that there was something different about its handling.
Thanks for your insight guys bobo54545 & Display_Name!
