Old Nov 29, 2007 | 02:51 AM
Steve Hellums's Avatar
Steve Hellums
Default Re: SL55 Y Pipe and Air intake pies fitted (pics)
Originally Posted by simon-srt6
Hi Shawn & Steve,
Did you need to cut any metal out for this mod, or does the larger pipe fit through the existing hole ok ?
If this is the case, I guess the only problem is fitting the 2 pipes together securly as one is tapered, is this correct ?
Si
Hi Simon, no metal had to be cut. Check out the post I made in the Tech & Mod. section of the forum, I just cut the top off the plastic piece's on each side of the radiator support. The reinfroced 2&1/4 ID hose's will fit through there, I used two 5" long piece's to stick the intake tube's through after using a heat gun & some pipe to take the ends of the tube's from 1&3/4" to 2&1/4". I had a pic of the pipe stuck in the tube's showing how they expanded, but I didn't get that pic posted.
