Old May 24, 2004 | 11:49 AM
WesMichaels's Avatar
WesMichaels
Default
With the dual cams the cams slide to change valve timing. As I said above.... If the intake and exhuast lobes are on the same cam you can't slide the cam to change valve timing and overlap at the same time. the overlap will always be the same. Just the timing will be changed.
