Old Dec 1, 2007 | 03:13 PM
SRTpowa's Avatar
SRTpowa
Default Re: 18.8.5 & 19.9.5 spacer question
I was looking at some ADR rims the other day. I believe the stock front rim is a 35mm offset and 7.5" wide, so the ADR 8.5" 35mm will stick out towards the fender one inch farther. So I'd say no need for a spacer up front.
11.7mm = 1/2 inch.
so a 20mm spacer on the rear would probally work to compensate for the higher 35mm offset on the 9.5" ADR, compared to the stock 22mm 9" rim. That's the way I see it. I think someone has pics with a 20mm spacer on here somewhere.
