Re: Turning of fuse's 17 & 18 w/remote
You know there is a break out box on the passenger side that has the hot leads from the TC/ABS system, it's the small plastic black box that flips open, I believe its the center lead. This does the same thing as the fuse removal and you can rev up to redline with this lead disconnected. It's a bit easier that running wires into the fuse panel or removing fuses.
